Screaming Eagle 103" stage 4 or 110" stage 1
Old 11-21-2014, 06:33 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
Hi,
thanks for your opinions
mirrmu
Old 11-21-2014, 08:01 PM
426power's Avatar
426power
426power is offline
My .02. Just freshen the motor up with some new pistons a little higher compression, have the heads done by a reputable builder and get a good set of cams. You will love it and it will be very reliable. I built a 95" motor like this and never had an issue with it. I had Branch do the heads and they were awesome.
Old 11-22-2014, 12:13 AM
drspencer's Avatar
drspencer
drspencer is offline
Originally Posted by SoZoomMe
........... The 110 is easier to ride because I don't have to keep RPMs up a little bit like I did with the Stage IV...
Why was the 103" Stage IV difficult to ride?
When did you have to keep the RPM's up on the Stage IV, at idle?
Thanks
Old 11-22-2014, 04:54 AM
SoZoomMe's Avatar
SoZoomMe
SoZoomMe is offline
Thanks
I had to keep them up a little bit (1,600 to 1,800) and work with the clutch at slow (parking lot?) speeds. Otherwise the bike would get jerky. It was a hoot to ride though.
Old 11-22-2014, 08:28 AM
DK's Limited's Avatar
DK's Limited
DK's Limited is offline
This is a great post, I have a 2013 FLHTK and want to do the same thing, I go from ordering the HD 110 kit, to calling Fuel Moto...decisions. I want more power in the 2,000 to 3,000 range...
Old 11-22-2014, 08:34 AM
kojak's Avatar
kojak
kojak is offline
Received 2,477 Likes on 1,234 Posts
I did the SE 110 kit on a 2009 ultra. I had the acr's, ventilator ac, true duals, se 255 cam and used the SE race tuner and had it dyno tuned. Kept the factory warranty intact and did 30k trouble free miles on the bike before selling it. Good low end torque, good midrange power, recommend as an upgrade from the 96 ci you have. You can easily spend $5k or more to hotrod and void your warranty and end up where you didn't want to go.
Old 11-22-2014, 08:55 AM
Kuz's Avatar
Kuz
Kuz is offline
Originally Posted by bald1der
As the title states looking at both these kits both about $2K. Now I know there are other kits that might be better and or cheaper. I'm looking at best bang for buck between these two. Looking for everyday ride ability and touring reliability. Also the ability to pull into just about any HD dealer and get it worked on if needed!!
I have the 103 with the stage 4 race kit and it produces 114 HP and 114 TQ, I highly doubt you will get that out of a 110 with a stage 1 kit.
Old 11-22-2014, 10:29 AM
kojak's Avatar
kojak
kojak is offline
My ultra was dyno'd at 115 hp and 118 TQ. However, I never pay attention to numbers but how a bike feels and it ran great for how I ride.
Old 11-22-2014, 10:56 AM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
mcr heads, 259 cam, 103 jugs,cast flat top pistons,adj pushrods,cometic 0.04 head gasket,mcr's total was $1500. made 98/105 with open true duals not bad?
Old 11-22-2014, 03:07 PM
drspencer's Avatar
drspencer
Did you have the bike Dyno tuned? If so, by who?
Do 255 cams have a jerky take off by nature, or can they be tuned to have a smooth start?
Thanks
Quick Reply: Screaming Eagle 103" stage 4 or 110" stage 1
