New fork oil ride question
Not exactly. H-D prefers to classify their fork oils in light, medium and heavy. Mostly for those that don't understand numeric sequences.
Their fork oils perform just like any other brand but I've found over the years that numerically classified fork oil is easier to work with because you don't have to also remember the numeric equivalent (and you don't sound like a dolt when discussing them).
And there's this: H-D prefers to cloak their lubricants in a veil of secrecy to keep competitors at bay.
I've used Bel Ray, Maxima and Spectro fork oils with great results. Once you start with a particular brand stay with it. There's no standard viscosity rating for fork oils so if you want consistency use the same brand even when going heavier or lighter.
To get half weights two oils can be mixed together - equal parts of 10wt + equal parts of 15wt will deliver 12.5 wt fork oil).
i went with 15 wt oil. tome. its to stiff for me because i probably added a ounce or 2 too much, but what is most important in fork oil changes is the amount you put back in. if you add just an ounce of 2 too much your ride will feel much stiffer and visa versa. its all about the air space in each fork leg so make sure that the amount you put back in is exactly what you took out. most folks dont know this unless you work on suspension all the time. it really is a science. many variations can be had with oil weight and amounts
Please don't follow this advice - it's a fool's errand. The correct amount is shown in the shop manual.
