Ok Shooter, with a T-taps how i can connect the tribar? As Dansflhti says, there isn't some external wire on the tribar....
I read in a French forum that someone has solved this way:
1- Open both the tribar (european and USA version)
2- Eemove both the electric board
3- Solder the 3 wires (black, white and red) to the respective pins on the USA electric board
4- Reseal and close the tribar box, install on the fascia and plug the 2 connectors.
Maybe a fastest and clearest work....
I agree with you guys,this is probably the way to go,install the USA light in the Euro box.I tried to get the pins out of oup cable connector,and it is a PIA.
So i will follow the French way
Engineers in Mo.Co. love to complicate life!
