Tribar 67774-10
Tribar 67774-10
Hi people,
I have a BIG problem with the tribar in object
Unfortunately the 67774-10 work for the USA motorcycles but is not suitable for the European models (the harness that go from the output tribar to the lights is different).
I have try to connect the two connectors but the two turn lights don't blink (in USA the turn lights remains always on while here in Europe always off and blink when we push the turn buttons on the handlebar).
Does anyone know how to fix or resolve this problem?
Maybe by changing the position of the wires in the output connector or other ways....
Someone has the scheme of the electric circuit inside the Tribar?
Thank you so much to all, i want to solve this problem, is a matter between me and the tribar
Greeting from Italy!!
Giuseppe
Giuseppe
It's a lot of work and that is the wrong part#. You need the part from the 2009 US bike when it had the large center taillight like ours. Canadian bikes are the same as yours. Here is a thread showing how to make it work:
https://www.hdforums.com/forum/touri...g-tri-bar.html
Thank you so much Snake, i've just read the thread but....i think that European and Canadian harness (from the tribat to the rear lights) are different I have 7 wires in input connector and 10 wires in output connector
I'll probably have to cut the wires and try to connect one at a time to verify proper wiring
For the precision, the wiring harness that go from the tribar to under the seat is exactly the same. The only different harness is the wiring that go from tribar to the rear lights.
In HDI harness the blink lights are green (7) and green/white (1) while stop lights are red (9) and red/white (3)
