Pc-v
Old 11-22-2014, 02:28 PM
UltraWalt's Avatar
UltraWalt
UltraWalt is offline
Default Pc-v
I recently change exhaust from 2-1-2 with a Screaming Eagle race tuner to a 2-1 and PC-V. My bike runs good, no decel popping however: it's doesn't start up very easily. I have updated the firmware on the PC-V and Fuel Moto has sent a new map but it has not help with starting. So today, I took the disconnected the PC-V and the bike starts right up with the touch of starter.
Any thoughts on why my bike is so hard to start using the PC-V but not the SC race tuner?
Old 11-22-2014, 02:44 PM
Mac10's Avatar
Mac10
Mac10 is offline
I have the Power Vision on my Road King. With the MAP provided from fuel moto it was running a little rough when i first would fire her up. Had it stalling a few times also. Just this past week in the cold in the 20 s. Once I rode it awhile it smoothed out. I ran an auto tune and now it's a lot better. But looks like you have the power commander
Old 11-22-2014, 03:44 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
did ya have a custom dyno tune with the sert,if ya did, did ya tell fuelmoto. the programing that the sert put in your ecm will not allow u to tune with a pc unless u return it to stock first.
Old 11-22-2014, 03:48 PM
fourburgs's Avatar
fourburgs
fourburgs is offline
Yea my 09 cranks aliile more also.. Not a big deal I got use to it. You can try hitting start before priming stops. some say it helps.. makes no diffrence with mine
Old 11-22-2014, 09:13 PM
UltraWalt's Avatar
UltraWalt
I did not have ecm back to stock and was told by several others that could be whats causing this. I will take it back to my local dealer and have them set the ecm back to stock. Thanks
Old 11-22-2014, 09:56 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
If you don't want to have the ecm put back to stock, just 0 out all the PCV numbers in the fuel and spark tables. I would add 5 to all cells in the fuel tables except the first column in the first three rows. You can leave them at 0. The 2 in 1 needs around 5% more fuel due to the better exhaust evacuation. The best thing would be to reset to stock numbers.
glider1993
08-07-2016 07:56 PM
Jeffinburlington
37
12-29-2014 11:02 PM
WebmonkeyL33T
12-30-2013 06:32 PM
Chicago Harley Boy
12-18-2013 12:24 PM
astiff
06-26-2012 09:57 AM
Quick Reply: Pc-v
