Sadly another seat question..
I've just picked up an 07' Ultra Classic and a buddy gave me a solo seat to try out. Awesome seat, but, I don't think it was made for my year. Mine doesn't have a spot for a bolt in the fender for the back of the seat, and there was a large gap between front of seat and fuel tank center trim panel. What seats will fit on a 07'? I'd like to pick up a street glide seat, instead of a solo. Is there a plug and play harness you can purchase so you can get the quick attach docking station for tour pack, or, do most people just cut the wires and install a harness connector?
seat from any street glide or road glide from '96-'07 will fit on your ultra. they have the shorter nose like the seat you put on but there is a panel that you can buy to fill the gap between the seat and console. http://www.jpcycles.com/search/searc...012733&Ntk=All
for the solo seat, I believe there is a bracket that mounts to the two studs under the seat that has a threaded hole to bolt down a solo seat. then you can get a bib to cover the exposed rear fender if you choose
How some solo seats mount ( this is a H-D Brawler on an 09 FLHTC):
seats for 08's are kinda mutts
seat for 09+ interchange to 15
seats from 07 down to about 1999 interchange ( maybe earlier)
for the detachable tourpak- some disconnect the wiring and roll it up under the seat or the left side cover if you don;t have ABS.
some ( very few) cut and splice...I did because I wanted to add extra circuits in the T/P for usb in addition to marker and brake lights...I used a flat 4 trailer plug.
I don;t have a cb antenna...my am/ fm is a rubber stubby on the left side off the inner saddlebag brace.
my plate hangs under my taillight.
mike
mike
How some solo seats mount ( this is a H-D Brawler on an 09 FLHTC): seats for 08's are kinda mutts seat for 09+ interchange to 15 seats from 07 down to about 1999 interchange ( maybe earlier) for the detachable tourpak- some disconnect the wiring and roll it up under the seat or the left side cover if you don;t have ABS. some ( very few) cut and splice...I did because I wanted to add extra circuits in the T/P for usb in addition to marker and brake lights...I used a flat 4 trailer plug. I don;t have a cb antenna...my am/ fm is a rubber stubby on the left sideoff the inner saddlebag brace. my plate hangs under my taillight. mike
