Smoke from one exhaust?
Hey guys I have a 2006 SG with around 6k miles on it. Today, after tightening the nuts for the exhaust stud, I let the bike idle for a few minutes and turned it off. Shortly after the right side side exhaust, looking from the rear was smoking. This was coming out the muffler so it wasn't the locktight burning off. What could this be, is there an issue?
Mods- True duals full Rhinehart system, stage 1 air cleaner, and PCV with a tune. Just making sure I don't have an issue here. Thanks all
Thanks for the replies guys.
I actually should clean the filter, not sure how that relates but I'll definitely take your advice and check it.
As for the O2, I'll check that as well.
I will check it again tomorrow and see if it does the same thing. Might be something minor and something I just happened to catch and notice. Thanks all
Thanks for the replies guys. I actually should clean the filter, not sure how that relates but I'll definitely take your advice and check it. As for the O2, I'll check that as well. I will check it again tomorrow and see if it does the same thing. Might be something minor and something I just happened to catch and notice. Thanks all
2010 Limited with some stuff!!
I'd like to see a 2006 with 6k miles on it! Mine's got 95k on it..[the guy I bought it from put the miles on it though]. The right side gets more exhaust through it,[with stock pipes],so any bit of oil or garbage coming out of cylinders will wind up on that side.Nothing to worry about. '06 doesn't have oxygen sensors. Oh I just re-read,see you have true duals! Still nothing to worry about.
Thanks guys, I think it was just one of those things I noticed and never noticed before. I'll check the A/C though, safe bet Sbates is right on this one.
@Akodust and HDBob, I just purchased the bike in July (coming from a softail, then a vrod). She had 4k on the clock when I bought her, so I put a good 2k-2400 on it since then. We don't get many nice days here so I do what I can, when I can. Don't worry she'll add up quick
