Rear will not work, period. Front wheel will need to be Non Abs bearings. Get yourself a 25mm axle. Get correct equal length spacers. Easiest would be to transfer your rotors over and VIOLA!!
Just read grbrown post. That's right. I had one of those wheels and realized the front rotors would not bolt up. I went with the Airstrike front wheel.
I installed one on my 07, and I just swapped the axle , rotors, and calipers. Your rotors will not bolt up to the wheel, and I don't believe your calipers will fit the new rotors.
There are two on sale at present at under 400 bucks, complete with rotors. As it is a recently introduced design I doubt if you will find any basement bargains just yet! You're not the first to like the idea of retrofitting one......
