searched and confused, fatboy rear on touring
Old 11-29-2014, 12:20 AM
gartec81's Avatar
gartec81
gartec81 is offline
Default searched and confused, fatboy rear on touring
So i was thinking of getting a fatboy solid rear. What years would i look fot to fit to a 04 road king
Would it just bolt on. Reading some say yes and others day machineing has to be done
Old 11-29-2014, 07:59 AM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
A 17 x4.5 or an 18 x 5.5 wheel will fit if you change the rear fender
The largest issue is not the wheel but the fender width and belt width
I have an 04 road glide with a 17 x 4.5 wheel. To make it fit required a rear fender change
Im still running t h e original belt
Old 11-29-2014, 08:14 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
If you use an early ball-bearing (not tapered bearing) FatBoy 3x16 wheel you'll be fine, however you will need to swap the 3/4" bearings for 1", which will need a new inner sleeve, also the hub will need to be machined to take that larger diameter spacer. Harley sells a bearing kit which comes with bearings and spacer. So it won't fit without mods, but they are easy to do.
I'm running a solid Deuce wheel in my 1990 bike, with an 04 swingarm, having modified the rear fender. It is not a bolt-in, you need to do some handiwork.
Old 11-29-2014, 10:50 AM
gartec81's Avatar
gartec81
gartec81 is offline
thanks for the info
sounds easy, im am looking for a 16x3 or 3.5 rear fatboy rim. not going any larger. any links to the bearing kit. or a link to a link to a previous thread that has some pics
how much you think that machine work would be
Old 11-29-2014, 11:50 AM
grbrown's Avatar
grbrown
grbrown is offline
Wink
This is the bearing kit. From what I can make out you need wheel #41058-00A, which was only available on 2000-3 models. Earlier ones are not suitable, even though they look similar, later ones are 17x4.5. There are a few suitable wheels on Ebay as we speak! I only buy wheels without a tyre, partly to reduce shipping costs, but also so I can fit my preferred brand.
emory70
Wheels/Tires
12-24-2014 10:48 AM
98suprglide
Wheels/Tires
12-07-2014 10:47 PM
CWild
07-04-2011 11:36 AM
bL33d
02-11-2009 06:56 PM
MsBobber
04-08-2008 07:55 PM
Quick Reply: searched and confused, fatboy rear on touring
