Exhaust gasket install
I just got a set of Vance & Hines Power Duals and fishtail slip-ons over the weekend for my 2011 RoadKing as an early Christmas present from my better half.
Put in the order for my Power Vision module from Fuel Moto this morning.
Pretty stoked.
Since this will be my first time swapping exhaust, I searched this site for any tips and advise.
One of the things I searched for is whether I should use the flat exhaust gasket supplied by V&H or use the stock cone exhaust gaskets from HD.
Opinion seems to be evenly split, so I am leaning toward using the cone gaskets since they provide more sealing material that the flat ones.
Although I had heard that I would need to be very careful when installing the exhaust gaskets, none of the threads made any mention of difficulty in installing them (either cone or flat).
I found a u-tube video by Bob LaRosa (FixMyHog) where he used a 50mm wheel bearing race installer to install the cone gaskets without crushing them.
I do not have this tool.
So, my question:
-what method have you used to install stock cone exhaust gaskets.
Thank You
Pretty stoked.
So, my question:
Thank You
Very easy...no tools necessary...I put mine in the freezer overnight to shrink them slightly...cleaned up the seat with a Drexel tool and wire brush...pulled one at a time out of the freezer with lubricant...I actually used Kroil but the brand/type isn't critical...and just worked them into place gently and evenly with my fingers. Easy peasy. ..
...One of the things I searched for is whether I should use the flat exhaust gasket supplied by V&H or use the stock cone exhaust gaskets from HD.
Opinion seems to be evenly split, so I am leaning toward using the cone gaskets since they provide more sealing material that the flat ones...
Just make certain all the old gasket material has been removed. Look very closely at the cylinder head as the old one may have come apart and left some material behind.
Then clean the surfaces real well. Some find freezing the new gasket helps while others don't. I usually use some grease to help slip in the new gasket making sure it goes it straight, square, and in the correct direction. It might be helpful to have an extra gasket just in case you damage the new one when installing.
Then torque per the recommended sequence and amount.
Trying to install those "cone shaped" gaskets is an effort in futility and frustration for no gain whatsoever. The Screamin Eagle gaskets are simple to install, don't leak and don't provide any restriction, which the stock ones do. The SE seal fine with about any pipe. I have V&H pipes and even though the end of the pipe is not totally square, as the edge is rounded, it seals perfectly.
But if you want to wrestle with those stock gaskets, go for it. Also remember that removing the old ones, which you will have to do regardless, is a bit of a job. I used a hook type tool to poke into them and pull them out.
