Slip on mufflers on water cooled 103
Old 12-01-2014, 10:10 PM
WNMORE's Avatar
WNMORE
WNMORE is offline
Default Slip on mufflers on water cooled 103
I asked a similar question on the Rushmore model forum.
Does the increased compression of the water cooled 103 engine change anything as to whether a tune is needed if slip on mufflers are put on the bike.
Thanks in advance.
Old 12-01-2014, 10:31 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
my opinion is that the catalytic converter in the exhaust header is the bottleneck to flow in the exhaust tract, not the mufflers- especially if the stock air cleaner is retained (it is somewhat restrictive too).
so- in your shoes i would go with my choice of slip ons.
with caveats:
1.) I know what pinging is and can recognise it- persisent pinging can damage your motor.
1b.) in which case I would probably use nightrider.com vieds/xieds for tuning compensation ( many riders prefer other devices)- if required.
2.) I would get a header with no cat and a high flow aircleaner...these added to the above will result in about 10 horsepower gained- for minimal additional cost. maybe $280
that's what i'd do.
Mike
Old 12-01-2014, 10:33 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Nope. Put 'em on and ride.
Old 12-01-2014, 10:46 PM
OwnerOfHarriet's Avatar
OwnerOfHarriet
OwnerOfHarriet is offline
from I have gathered, the 14 and up Rushmores have a better flow through the air cleaner --
and really, the cat is the restrictive part of the system -- should not have to do anything more --
Old 12-02-2014, 04:47 PM
bklynbob's Avatar
bklynbob
bklynbob is offline
The ecm will compensate for a slight increase in flow. It will still run an A/F of 14.7-14.9, in other words it won't run all that much better. Go for a tuner and dyno tune and really enjoy the ride.........
RatPwrd72
08-16-2013 11:19 AM
brummie
09-25-2011 09:17 PM
fzggm4
06-29-2011 11:40 AM
plumbertom
06-07-2010 09:38 PM
DamifIknow
Exhaust System Topics
08-03-2009 07:28 PM
Quick Reply: Slip on mufflers on water cooled 103
