broken tab
broken tab
2005 ultra , the triangle mounting bracket for the starter has a tab up top where it supports the exhaust out of the rear head , the tab that goes under the exhaust clamp is broke. was gonna just spot weld it in place while on the bike , question is , is that gonna hurt any electrical componants by spot welding it there ,should I remove the battery , main fuse etc....
thanks mike
thanks mike
Is that the little " L " piece. Part number 65619-98 that is like an $8 dollar item.
It breaks right at the bend..Make sure to check the rubber blocks that support the slip-ons also because if they are hard and binding then it locks the support system creates pressure for the entire support system.
Why not just remove it and weld off the bike thus avoiding any potential problem.
You could then weld it nice and neat and grind any extra off and could even high temp paint it.
Or just order the part from a local dealer for the $8.
double check the number on the ronnie harley davidson microfich
I don't think it's a critical piece myself. Mine was broken for who knows how long before I removed the exhaust and discovered it to be in two pieces.
I mail ordered a replacement and had it in a few days. Yea, I could weld it, but for me the few dollars for a new one offset the time and effort of digging out my welder.
I doubt that it would hurt anything to run it the rest of the week while broken. I don't think I'd weld it in place, tho...concerned about spatter, but if it's only eight bucks, I think were it me, I'd replace rather than repair...and weld up the broken one next time I was welding on something else!
