how can I tell if my battery is about to die
There is one foolproof way to test them and that's with a load tester. It's a voltmeter and dummy load that works by applying a DC load for a short duration to a starter battery, simulating cranking. The voltage drop and recovery time provide a good indication of battery health. To do a CCA pass/fail test, load a fully charged starter battery with half the rated CCA value for 15 seconds. To pass, the voltage must stay above 9.6V at 10º C (50º F) and higher.
Yes, so true...You're better off listening to what the battery is telling you rather than rely on this test and that test! Have had the same thing happen to me. When the battery gets undependable, it's gone. If it's indicating a good charge either by the OEM voltmeter on the dash or by me using a multi-meter, I get it!
Get a tender. They can be bought for about $20 at Wal Mart. The only thing you are doing by starting the bike up and letting it run for a bit is allowing condensation to build up in the tank. Not a good thing.
Received 47,779 Likes
Location: Western Illinois, land of bad roads, and corrupt politicians
I've noticed that a fresh battery will start the bike, and the radio stays on. When the battery is starting to get old, the radio will reboot once in a while, while the engine cranks. When the battery is really getting old the radio will reboot every time I start the bike, and there will be a little hesitation while it cranks. Then when you go out to take a ride on an absolutely gorgeous day, the battery will be dead as a door nail.
Then it's time to do your best Yosemite Sam swear, and buy a new battery.
Gave me an opportunity to test the responsiveness of AAA again....30 minutes. I told him to just replace the battery, and now I'm good.
FWIW...the cage had recently passed by 5 months my 4 year window where I replace the batteries as a preventative measure.
Clean and tighten all the cables on your bike and give it a good charge (not trickle charge). Then determine if you need a new battery.
Note: Replaced battery on my F150 last week. It was still cranking good, never had any problems with it but, it was 11 years old. I bought the truck new in 2003.
