Cam bearing seating depth after flush
The book says 3.1" from cam cover flange. That was too hard for me to measure. I am looking for the measurement from flush like .005" below. I thought I could tap the cam bearing in until the socket makes contact, put a round shim on the socket and tap until the socket is flush again, and the bearing is seated the exact amount of the shim. Simply brilliant, except not sure what the measurement below flush should be. 2009 with 96ci motor.
Mark
I know guys do it every day,but there's not a bearing out there I would pound in. There's a guy selling cam bearing tool in the classified these tools will set the bearings in precisely at the depth they need to be. If you ever knock the bearings loose and they go to the bottom of your case you have just created yourself one hell of a headache. Better safe than sorry,just saying
Heartland Tools makes several versions of cam bearing puller/installer tools and the installation tool is designed to put the bearing in at the proper depth. That's the way I would go rather than driving the bearings in. Ebay has Heartland tools auctions. Pretty affordable too.
