is changing boss fatcat to boarzilla on 117 a mistake
Currently has a 58mm to 5.3 injectors woods 888 cams 10.5 to 1 Pistons with heads shaved .040 to get the compression at 11.0 - 11.2 , heads are stage 3 screaming eagle . Boss fatcat 2 into 1 exhaust . 120 hp 132 to. So I wasn,t that happy with my hp number and think I need more cam . Looking at the new wood 999 which is their modified tw8-9 . Only want to do it once so that's why I,m looking at the boarzilla
What baffle fatcat? If it's the quiet baffle I'd change it out but then again 1k is a lot of money. I have both pipes in my garage. Took the quiet fatcat off to run a Borezilla on my 124. I thinkYou will get better lower numbers and response from the fatcat. The Zilla will be better up top but how often do you ride at 5-6k Rpms
What does your Builder / Tuner have to say?
need input. I am thinking of changing my boss fatcat to a boarzilla on my 117 build. I know its right on the line of either exhaust, will I lose tourqe and is the expense worth it for just a number or two. thanks
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
