Windshield Help
Windshield Help
I am thinking about replacing the stock shield on my 09 Ultra Classic, due to wind buffeting and noise. It seems that the stock windshield and I are just the wrong heights for each other. Anyone have any experience with any of these: Klock Werks 11.5" Flare Windshield, National Cycle VStream Windshield, National Cycle Wave Windshield, or the Kuryakyn AirMaster Aerodynamic Windshield?
looks like you are thinking about going higher.
the bigger the hole you try to push through the air, the more pressure differential in the cockpit.
uncontrolled air will rush in from the sides and below.
I use the fairing wind deflectors to pull "controlled" air into the cockpit.
I also cut my windscreens down ( the bottom edge is easily cut with a dremel, rotozip, jigsaw- and the cut is hidden).
you might want to give a try...for me the correct height is so that the top edge "appears" to intersect the road about 40' ahead.
I don;t like recurves as in crap weather I want to be able to tuck into the fairing and look through the windscreen
not all are created equal- the HD Lexan is tough and optically very good.
i have seen cheapos deform from cleaning or crack/ shatter from a rock, discolor from UV
Mike
Mike
Check our Long Ride (LRS) they have shields for both single and two up -- I have both styles one bike has the two and the other the one up. My wife noticed a difference right away with the 2 up version . As a rider I don't. I have to measure to see which length I have -- but they are shorter than stock
I have a 2009 ultra classic and just switched out my stock 13 inch for a LRS recurved 13 inch ultra elite polycarbonate light tint. Looks great, fantastic price, and is truly amazing the difference between the two shields. Easy install too. You need to look at LRS.
