Solo Detach Tour Pack Setup 2009 And Newer
HD accessory book says locking detach lock will not work on the solo detach rack 2009 and up. (it worked on my 2008, just bent the key 90°)
Any of you guys that use this setup use a lock of any kind?
I have a 2015 Road Glide and both solo and 2-up tour pack racks.
I see Brukus has a locking bullet.
Thanks in advance
Thanks in advance
I use the lock on my solo T Pak rack on my 09 FLHP. Yes it did say that it wouldn't work but I ended up taking the key barrel off of its shaft so that I could unlock it:
If I can find the photo showing this installed I will add it...EDIT...here is a photo showing locked position:
Sitting between the solo rack and the bottom of the T Pack is the Kury T Pak relocator.
Edit: Since I had to take off the T Pak yesterday, here is a shot with the key inserted:
I believe HD changed the PNs in the 2014 model year for all of the 2 and 4-point docking equipment so I don't know if this will work on your ride.
Received 1,503 Likes
plutnicki
09-01-2013 10:05 AM
