Baker announces new compensator kit
So I've been watching news re the rumored baker comp. Planned to replace my 09 oem comp this winter, and just recently got the full parts kit from my dealer. All still in factory boxes. Now bakers's is about to be available. It looks sweet.
What should I do? Get the Baker and take a hit on selling the replacement HD parts? At least I can use rotor, right?
Anyway use what you got.. If it wears out, the next generation of whatever will be out..
patience...
I'm gonna wait a bit before ordering. I would whole heartedly agree that Baker makes great stuff, but there are about 8 forum members pre-testing the compensator as we speak. Sure couldn't hurt to wait a couple months and get some feedback from these guys after they've put on several thousand miles or more. $400 plus a $100 rotor in my case is a lot of money (at least for me it is...). However, I'm pretty convinced this is the one to get even if they have to work out some bugs, especially considering the alternatives (SE comp with plastic parts and glue in the primary--which still has failures, darkhorse which sadly may never see the light of day, and the BDL and Vulcanworks solid sprockets). Keep following the thread titled "darkhorse compensator" where Mark from Baker has provided some great info. Oh yeah, don't forget about the 10% discount for HD Forums members.
Thanks for the replies. I'm going to install the SE parts I have in boxes. My bike is on a lift and partly apart, so I feel like I need to finish this now. Even with Bakers's great reputation I'd prefer to wait until after its product has been in use for a while, so the timing is not working. Also, the parts were special ordered so there will be restocking charges. ... What a hassle. Harley can be rough on its customers.
Yub,had same thought & tried a new starter,still had same noise which is when i joined this onloine HDfroum and read that the slam/bangs sound you get when firing up the bike is sign of bad comp.
And i also read if you sometimes get kind of a lurchy tweaky feel as your engaging the clutch taking off in 1st gear thats also a sign of a bad comp which the bike started doing along with the loud clang/bang sound from primary case when firing up too.
So i feel the compensators the issue and wanted to go with Bakers new comp but from what i read on thier site i'd need a new rotor for my bike which is an additional $125 or so on top of the $400 totaling $525 when i can get the upgraded SE heavy comp for $353 online delivered to my house and not have to buy a new rotor so thats the way i am going.
I have read here on the forum that the newer design heavy duty SE comps are doing better/lasting much longer then the stock original comp so at $175 less then going with the new Baker comp i figured i'd give it a try because i am not loaded with $$$$.
The $175 i save pays for the progressive front lowering spring kit & lowering brackets for rear shocks off Ebay with a few bucks to spare.
And yes i am aware you have epoxy oil deflectors in the primary case with the upgraded SE comp kit!/LOL!!
Scott
Scott
I have an unused HD epoxy kit. Paid ~ $54. Does anyone know how many oil deflector cup installs can be completed with one kit, and how long the stuff will last once opened? It looks like the kit will do 3-4 cup installs.
If the kit has a shelf life after being opened, which I expect it has, I'll share the leftover with a member doing this project. Member covers postage. I'll probably be done in mid February.
