Magnum clutch cable to short?
Old 01-18-2015, 09:36 AM
mfortkamp's Avatar
mfortkamp
mfortkamp is offline
Default Magnum clutch cable to short?
I installed 13" prime apes and am to the point of putting in my clutch cable. It seems too tight or short compared to my stock cable as far as adjustment. After installing it I only spread the adjustment screw apart maybe 1/8" to get proper free play. My stock cable probably had 3/4-7/8" gap between the nuts on the adjustment screw. The clutch feels fine as far as pull and engagement. Anyone else experience this?
Old 01-18-2015, 09:43 AM
Northbound Southerner's Avatar
Northbound Southerner is offline
New cables will stretch a little. Did you do a full adjustment starting with the clutch basket?
Old 01-18-2015, 10:21 AM
mfortkamp's Avatar
mfortkamp
No I haven't. I'm not to that point just getting cables ran and was hooking it up to clutch lever and was having issues getting it in there. I didn't want to get to far to find out it wasn't the right cable
Old 01-18-2015, 10:23 AM
It will be fine. Do a full adjustment at the clutch basket. Between that and the new cable stretching a bit, you will have plenty of adjustment. You probably should have taken the basket preload off before adding the cable. You are gonna do it anyway to properly adjust it before you are finished.
Old 01-20-2015, 02:10 PM
slammed05fatty's Avatar
slammed05fatty
slammed05fatty is offline
i hated my magnums, i always had a loose cable and adjusted it constantly, not sure of your exact issue though. did you order the cable too short?
Old 01-20-2015, 09:34 PM
crimson13's Avatar
crimson13
crimson13 is offline
Same issue with my magnums they were the right length but had hardly any adjustment.
Rocker B
07-05-2019 03:03 AM
Venture72
General Topics/Tech Tips
03-02-2017 05:58 PM
Dieselhed
08-09-2009 06:12 AM
sargek
06-15-2009 11:44 PM
ronyd
03-19-2008 10:39 AM
Quick Reply: Magnum clutch cable to short?
