Electra Glide Classic Tires
I believe its a 140mm tire size.
We have some and others in stock, if you would like to check some out visit www.wanaryd.com.
Hope I was helpful!!
Your stock tyre was probably an MU85, which corresponds to a 140/85. If you have the later 1 1/8" narrow belt you should find that a 150/80 will fit with ample clearance, however check load rating, as there are suitable versions, but also some lower rated tyres for lighter bikes. You are looking for a load rating of around 76/77.
A 150/80 has the same rolling diameter as the MU and to be frank I didn't detect any change in handling, just looks a bit better! If you have the wide 1 1/2" belt you may struggle to get it in - some members have reported getting one on, but I had to change to the narrow belt on my bike.
Johnny1956
03-18-2011 11:16 PM
