SE-585 vs SE-259E camshaft
#31
My 15 street glide goes in on June 6th to get a Stage 4 Race Kit, (warranties are overrated anyways right?? ) swapping to SE585 cams and going with Vance and Hines Hi Performance Stainless Duals, Builder thinks it should pull Very strong torque curve and still get good horsepower, I am hoping the pipes aren't too much for the torque curve.. but he sais the cross over they have should save me.... Hope so,,, awful expensive gamble
#32
#33
Stage III
just got back from the dealer had stage 3 done , Stage 3 kit, SE Chisel aie cleaner, fuel moto 2-1-2 head pipe, SE Street canons mufflers. = 83.7 HP, 109.33 TQ ,
109.33 tq
109.33 tq 83.70 hp
Tech at shop said he did not like fuel moto head pipe, liked vance and hines better, may have gotten more from vance and hines exhaust. anyway was trying to take it easy cause everything is new , feels smooth nice power.
A little more torque than hd website says kit will make. their site says 100 tq and 88 hp.
109.33 tq
109.33 tq 83.70 hp
#34
109.33 tq
109.33 tq 83.70 hp
109.33 tq
109.33 tq 83.70 hp
#35
#36
There's nothing wrong with the Fuel-Moto 2-1-2 pipe except maybe the mufflers you installed and the tune to your bike. I had a friend with a 2014 SG with a decatted pipe tuned with the stock cams did 90hp and 110tq. The jagged lines from your sheet don't look to good and the AFR line looks like it was drawed with a straight edge. I'm not trying to be mean or critical which is the way it may sound but I'd think you would get more than that if properly tuned.
Oh I am not mad at you I am a little disappointed at the dealer, slash tech, Harley Davidson......I had cut off the bottom of the dyno sheet, but here is a pic of it, I was trying to get a close up of the numbers cause some guys post their sheets and you can't read them. See they loaded a map for a motor with full sac x pipe (they don't sell fuel moto pipes). then probably tweaked it so it would run smooth, you know if you are riding and hear a little decel pop or hesitation, then everyone thinks it is running good, but not necessarily true, and if you set a motor up a little rich it will be running smooth and cool safe for the motor and smooth for the customer. Plus if you are a flat rate dealer tech you are not going to spend hours on a dyno just to get it right. if you have been doing this for a while you have maps saved you can load and get you number good so the bike runs ok. I noticed that the bike woke up when I took the cat off and did the air cleaner. I did not have the bike dynoed so who knows. But if you go to harleys website it says the cams will make 100 tq and 88 hp, mine made 109.33 tq 83.7 hp. so I did get more TQ than HD says it will , but hp is a little down, who knows with a different tune or exhaust.
#37
#38
If mine pulls those kind of numbers I will be Very Happy,, My biggest concern is I want a very Flat torque curve
#39
The Jackpot 2/1/2 head pipe will support 120+Hp and has been tested in literally thousands of applications. The pipe is not holding your numbers back. Take a look at the smoothness (or lack there of) of the dyno curve, I would look straight at the tune; most specifically the spark tables. I would also ask the specific engine temp the runs were made at, if the motor is past optimum temp or does not have proper airflow from the dyno fans it can have the same effect on the dyno chart.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
#40
I noticed a difference in how the bike ran when i put your pipe on and the air cleaner, I just could not get it tuned right, and not having a dyno and afr meter I did not feel like i could do a good job so I brought it to the dealer , and since I wanted to do the stage 3 kit I figured why not. I do feel a little sad because the only difference I really notice is a little cam lope at idle and more oil pressure cause I had them do the oil pump / cam plate upgrade.
I got my old parts back and did see the old pistons are all oil fouled and did see post of guys doing the breather buy pass, I don't know if this will help it run better but I only have 8K miles on the bike and the pistons look horrible. so that is my next project. When I get home I will put some pictures of the old pistons on here.
Yes I was surprised that the TQ was more than Harley said it would be in their add but you don't know what air filter and exhaust they had, and reading the post of guys on here that only did air cleaner and full exhaust I would think I would have gotten MORE. From that set up.
Do you know any good tuners in the phoenix area?
