I second WalMart for Mobil1. Runs $9.97 a quart, with no "membership" or "preferred customer" crap. I used to run Amsoil, and have no qualms with it, other than availability.
The preferred customer "crap" only costs $10 every six months. I more than make up for that with the amount of oil changes done in all my vehicles.
We'll get a billion responses for which oil is best. What's more important is that you stay on top of your oil changes.
If you're running dino oil and then switch to full syn without getting all the old out is that ok? Some people are very **** about not mixing. I don't think it's a problem and after 3 or 4 oil changes it will all be worked out of the system. Just throwing it out there.
Unless you plan to dismantle the entire engine, you'll never get all the old oil out. Just drain it, and refill it with synthetic. You are 100% correct, after 3 or 4 changes, it won't matter.
You don't have to dismantle the motor to get all the oil out. There's a product out there on the market to make it easier to get it all out. Or you could pull the plugs and crank it over. The pump should return most of it to the reservoir and then it'll drain out the drain hole.
