Powervision 2 and Autotune Pro and check engine light
I have a 2015 Limited. Today, my buddy and I installed a fuel moto power package consisting of the fuel moto 2-1-2 head pipe, pro billet a/c, e-series mufflers and a power vision 2. Also, we installed the autotune pro for the power vision 2. I loaded the custom tune that Fuel Moto provided for the power package.
Install went fine, but the check engine light is staying on. Following are the DTCs from the power vision:
P0031 HIST CURR
Front H02S low/open
P0051 HIST CURR
Rear H02S low/open
P0134 HIST
Oxygen sensor high/open (front)
P0154 HIST
Oxygen sensor high/open (rear)
I am just learning about the power vision. Does it automatically recognize the autotune pro tuner module? I haven't changed any of the settings that it came with.
Thanks for any help.
P0031 HIST CURR
Front H02S low/open
P0051 HIST CURR
Rear H02S low/open
P0134 HIST
P0154 HIST
Make sure your O2 sensors are installed correct, black goes to the back port and that both of them are connected. Also, make sure that the heated O2 sensors is turned on in your custom tune ---Limits and Switches - Heated O2 Sensors - the value should be 1.
I have the same setup on my 15 CVO and had no issues.
I am using the wide band sensors that came with the Autotune Pro kit. I left the narrow band sensors in the OEM pipe that I removed. I put plugs in the narrow band bungs on the Fuel Moto pipe.
I believe the O2 sensors are connected properly.
I did enable the Autotune Pro in the Power Vision, but with it being night, I have not taken the bike out for a spin. I cleared the codes. I will ride it tomorrow. Hopefully, the engine check light will go off.
Thanks for the responses and if anyone has anything other suggestions, I will check them out.
You MUST use both narrow and the wide bad O2 sensors with the pro kit. Take the bung plugs out and place your OEM narrow band O2 sensors back in to the Fuel Moto head pipe.
The pro tune kit is not a replacement for the OEM O2 sensors and the instructions don't tell you to take them out.
That's your problem....
Most can be installed in pipe while it is on bike. You do realize the wideband O2's only work in Autotune PRO mode and the narrowband O2's are the ones the ecm/can uses realtime. Once you get the 12 mm back in just clear the codes and make sure they are turned on in Win/pv which they probably are.
