Taking timer cover off to replace with a new one and 3 of the 5 screws broke off. Two are flush and one is partially sticking out. Someone guide me on how to fix. Give me the brand of tool to use. What cheap *** screws. Thanks for any help
If you have a little of the screw sticking out , you an try to put cut in it with a dremel and use a flat head screw driver if not like others have said left handed bits and a steady hand will get you fixed up
sometimes u can get lucky and get it moving using a small punch and tap hammer. next time get a handheld impact driver b4 u try and remove cover screws,saves a lot of time removing broken or rounded out heads.
