Thinking about a 95 upgrade. Got questions.
When my 02 Dyna was our primary two up bike I had the 95" kit and 203 cams installed. Didn't do any head work or compression work (shave heads), the bike would walk away from the then standard 96" engines. Real good seat of the pants pull and roll on acceleration. The 02 is my daily driver and manages the traffic real well. Since the BB was installed I've also put the hybrid cam plate/SE oil pump in and quite happy with those results.
I'm not sure what compression the 203's like, but I'm sure there are many here that do. You will need to have the cylinders bored. If you don't have a good local shop, consider one of the forum sponsors or members that have a good reputation here. They can also advise what compression will work best.
Hillside Cycle and Fuel Moto have excellent reputations here, as does Kirby Apathy of Vee Twin Performance.
Check them out:
www.hillsidecycle.com
http://www.veetwinperformance.com/
http://www.fuelmotousa.com/
I just got off the phone with Scott at Hillside Cycles. He said a 98 kit and their stage 1 heads would run me about $1250 plus shipping. I would need to send them my jugs and heads, they would do their thing to them, and they would sent them back with the pistons already ringed and with everything else I would need to do the swap.
Sound good?
Sound good?
Sound good?
Sound good?
The second thing I might do different is send my 06 heads to Big Boyz. Only after putting it all back together with the 'ported' heads I got, I found them and in reading their site, discovered they do the ports the way I really wanted them done in the first place. Too late now though.
