Thinking about a 95 upgrade. Got questions.
I currently have the stock 88 motor on my 2004 FLHRI. I recently upgraded to the SE hydraulic cam tensioner kit and went with SE204 cams at the same time. The lifters were replaced, SE adjustable pushrods were installed, along with the SE clutch spring. The bike was dyno-tuned with the SE performance tuner. Everything was done at the dealership. I already had a K&N air filter and MGS True Duals installed.
I'm kicking around the idea of upgrading to a BB kit. I'm thinking 95. My idea is to just swap out the jugs and pistons and then have it retuned. I understand that I'll need some special tools, gaskets, and other misc items to do this. I have a service manual to assist in the labor.
I've seen that some folks don't care for the SE BB kits and have chosen to go the aftermarket route. I'm looking to get the most bang for my buck so any recommendations would be appreciated. I'm not looking for a speed-demon, just a little more power. So I'm not really interested in doing a bunch of expensive head work.
Is there anything else I should consider or is this a pretty straight forward upgrade.
All you need is to do the jugs, pistons and rings. HD or aftermarket will work. You may have more choice of compression ratio's with aftermarket parts.
If I were doing it, I'd go with a local performance shop or one of our online sponsors and go with their choice of pistons when they bore the cylinders. They will usually fit the pistons and rings as part of the process.
Do you have any recommendations as far as compression ratios or aftermarket kits?
Big Bore kit from Hillside Cycle, a sponsor in here. 98", jugs, custom pistons machined to your cam specs, fitted rings installed, full Cometic gasket kit and all the help from them you can ask for. About $650, but that was 2 years ago. Scott is a great guy to talk with, he won't try to sell you anything you don't want. Can't say enough about my experience.
Received 4,307 Likes
When my 02 Dyna was our primary two up bike I had the 95" kit and 203 cams installed. Didn't do any head work or compression work (shave heads), the bike would walk away from the then standard 96" engines. Real good seat of the pants pull and roll on acceleration. The 02 is my daily driver and manages the traffic real well. Since the BB was installed I've also put the hybrid cam plate/SE oil pump in and quite happy with those results.
