cold startup rattle
My 2012 Limited did it, my wife's 2012 Triglide does it and my 2013 Limited does it. I run Mobile 1 V-Twin oil. The wife's Tri has 25,000 miles on it and the 2012 Limited had 31,000 miles with no adverse effects. This doesn't keep you from being annoyed, but I don't think it is a mechanical problem to worry about.
Bill
Bill
sometimes something loose in the exhaust will rattle until it expands...check the easy stuff unless you have direct knowledge that there is a problem with the valvetrain
oil: correct grade for your climate/season? a heavier oil will not flow as easily when cold...
mike
mike
Is you motor by any chance modded with hot cams having higher spring pressure rate that can put more pressure on the hyd lifters overnight making them more likely to bleed down overnight?
That could situation could make hyd lifters blled down overnight having to be pumped up again which takes a few seconds to until oil pressure's up to normal firing up cold.
As long as the lifters/valve train stays relatively quiet after it quiets down post starting cold and motor getting to full oil pressure a few seconds later you have nothing to worry about.
But with that said i have hit that issue in the past when running syn oil that at times can thin a bit more then std dino does which can be an issue with hyd lifters.
That can happen when a hyd lifter has a little more internal clearance between plunger and lifter body then it should adding to the bleed down issues over night & when i tried some std dino like spectro 25-60 it fixed the issue because it didnt allow the lifter/s to fully bleed down overnight anymore.
But dont regularly run that oil below 45-50 deg F.
It's specifically mfg'd & formulated for air cooler Harley V-twins per mfg.
See below for link and info on the oil.
Scott
http://www.spectroshop.com/heavy-dut...60/prod_60.htm
Product Information
Heavy Duty
Spectro Heavy Duty Engine Oil is a superior motor lubricant designed specifically for use in American-made Harley® V-Twin engines. Crafted from superior petroleum stocks combined with the most advanced anti-wear, anti-carbon additive systems available, Spectro Heavy Duty extends component life, reduces wear, eliminates valve sticking. Meets all known OEM warranty requirements. Exceeds A.P.I. SF/SG – CD/CG - 4.
Be the first to review this product!
Price: $8.93
Product Code: R.HD2560
I have a 2013 flhtk. mine does the same thing. but I found out my rattle is my cross over pipe. goes away when it warms up. and I am using amsoil 20-50.
