cam chain tensioners
Yes they fail and yes it is very expensive. I think Hyd ones started in '06?? If so they are better but should still be checked around 50K imho. Spring one checked around 20K and replaced with Cyco shoes. I'm a fan of Andrews 26 in stage 1 88s but your '06 heads will handle 48s, which may be a better choice.
I had to replace an engine after tensioner failure, because extended said it was cheaper than a rebuild. Now that they don't have the reman program it would probably cost close to the same.
I personally would do Andrews conversion cams, get an 07 cam plate, and use the new style chains, and tensioners, the new style of chain is a roller type chain , and will wear to the rollers ,and pretty much stop. You still should open it, and check them at 50-60k though.
I did this upgrade on the cheap, using a take off low mile 07 cam plate that someone was replacing with a billet plate. I also used Andrews cams, but went with 21N's instead of 26. Not only do you lose the spring loaded tensioners, but you get a better oil pump. I reused the original pushrods to save money but it's more work to do it that way. You will need some specific tools, most notably the cam bearing puller/installation tool.
Those cams are usually pressed into bearings which are pressed into the Cam plate. With the 07 they just slip into the Cam plate right? The stock cams will just slip in (no pressing) or do I need a different 07 style cam or something?
Thanks for any light on this subject.
John, just for my education because I know this will come up with a few friends bikes - again - when you go to the 07 Cam plate can you reuse the stock Cams and Cam gears?
Note the post you quoted, he uses a Andrews 21N cams. The "N" designates small bearing in the block and large bearing surface in the cam plate.
