Stock 2-1-2 exhaust crossover loose
Is there a trick to keeping the stock 2-1-2 exhaust crossover tube snug? A friend of mine is running this setup and noticed that the left side of exhaust with crossover can move as much as an inch in and out where the crossover clamp and gasket is. We have tried torquing that clamp down but are leary of torquing too much and cracking the pipe.
Any tips to get this seated and sealed correctly so it doesnt move or is this normal?
Pic below is a jackpot header but should give a good idea of what he has.
torca isn;t cheap...that's what Harley uses.
torque spec on those is about 35 ft lbs...start at 27 pounds first use and each re-use go up 2 pounds.
good thing you are there- hanging the exhaust evenly really is a 2 man job...1 needs to sit on a milk crate with a beer to eyeball the mufflers are straight...while the other guy takes care of the swearing
mike
mike
I had the same problem...couldn't tighten the clamp enough to keep it from moving around...I went to the parts department and got an insert that go in the crossover pipe...first cut out the old one, it is made of a wire mesh and some type of compound...this thing gets mashed and won't seal....the new one slides in kind of snug, so be careful not to bend it....after getting it fitted properly, put the pipes together with a new clamp....I had no more problems with it......good luck
Clamps
Those clamps are considered one use,however,a friend told me to check something when I had similar prob. It appears that the spacer in the middle can seize on the bolt giving false torque readings. I Removed center spacer and drilled out the hole so bolt would slide freely performed mod to all three clamps. Had everything loose ,aligned the pipes and snugged in 10lb increments. Ran bike till warm retorqed bolts. I'll check torque after a few rides.
