2008 Brembo brake rebuild kit
Howdy
I got a 2008 cvo roadking with Brembo front brakes that need a rebuild including pistons,well after web searching I got a Drag Specialities part no 1702-0117 but this kit is now discontinued,anyone no where I could get a kit to rebuild these calipers?
thanks
John
thanks
John
thanks guys,I would love to change the pistons when I go that far,have a weep from 1 caliper and would be great to do the lot when I'm at it,the Drag Specialities kit had the pistons included for $42,its a pity they discontinued them,rebuilding those calipers should be getting common from now on as the years add up
Someone should take the o'rings, looks like a quad ring, a back up ring and a small o'ring to the local o'ring house such as Parker Hannifin and have them matched up. Be sure and tell them it's for brake fluid. Then publish the numbers for all to see. Anyone measure the piston diameter and width? I read some where Honda uses the same size Brembo stuff.
