cam help
Old 02-28-2015, 01:43 PM
jt metal's Avatar
jt metal
jt metal is offline
Default cam help
'12 street glide w/ open air filter and slip ons.
Want more passing power at 40mph. Don't want to give up much anywhere else. Really want the bike to pull harder thru out.
Ride a passenger half the time. And that's when this little booger is a real pig!
Old 02-28-2015, 01:48 PM
themensh's Avatar
themensh
themensh is offline
drop down a gear, apply more throttle. That is the cheaper answer.
Old 02-28-2015, 01:53 PM
RoadsterGlide's Avatar
RoadsterGlide
RoadsterGlide is offline
I used to have a 2011 SG with slip-ons, air cleaner, SE race tuner. Was looking for a good bolt-in cam and went with the HD's SE 204...good mid range cam. It woke up the bike even more, but I seldom rode 2-up so I can't speak to how it pulls all day with that load. With higher lift cams there are some compromises, and I didn't want to tear into the engine.
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is offline
Andrews 57s, & about 20 others, Andrews are the least expensive & work well.
Old 02-28-2015, 01:55 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
A set of TTS-100 cams should do the trick.
Old 02-28-2015, 02:05 PM
Tinman265's Avatar
Tinman265
Tinman265 is offline
Second vote for the Andrews 57H
Ventilator a/c
Fuel moto Jackpot header
Big Louie mufflers
SESEPT
110 ft lbs
96 HP
Over 100 ft lbs from 2700 to 5000 rpm
Old 02-28-2015, 02:18 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
KSGLIDEGUY is offline
A good low to mid rpm cam would also be a Woods 222 cam. I had them in my 08 SG and it made a big difference, especially when my wife rode with me. I have also heard alot of good things about the 57h.
DBLX's Avatar
DBLX
DBLX is offline
There are much better cams available than the SE series! I went with T-Man performance. No regrets!
Old 02-28-2015, 02:24 PM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,317 Likes on 3,267 Posts
Andrews 48
Old 02-28-2015, 02:44 PM
jt metal's Avatar
jt metal
jt metal is offline
Maybe a 120" is better suited for my needs. Wonder how much that is????
I just hate doing things twice. Or three times for that matter......lol!
Who's 120" upgrade is making headway as of today?
Quick Reply: cam help
