Wild 1 Chubby Apes
Does WO578 bars utilize existing cables? Thanks
Yes on my 13 CVO Ultra and yes on 15 FLHTK (both have Hydraulic brakes and clutch). You have to cut the black tie wrap on the riser and move the hydraulic lines around a little bit. Also, on the 15 FLHTK had to add the electrical extender wire kit which costs about $25.
NOTE: The hydraulic lines will be tight going thru the fairing on some models and lines may rub. If you're concerned about it get longer cables. On my 13 CVO they rubbed the inner fairing but didn't bother me. On the 15 FLHTK was able to tie then off so they don't rub..
Call Wild1 Chubby directly and they will answer any questions you may have. Great customer service.
http://wild1inc.com/
Let me get this right, the 575's are taller and wider than stock, but closer to the rider?
I have my stock bars pushed ahead all the way, maybe 1/4 from touching inner fairing where they are closest to the inner fairing. This in an attempt to make them sorta higher as I'm 6'2".
Not overly crazy about the thought that the 575's are closer to me?
Is this a situation where I should skip the 575's in favor of 578's?
Sorry for the thread hijack, your help is appreciated!
