Wild 1 Chubby Apes
Let me get this right, the 575's are taller and wider than stock, but closer to the rider?
I have my stock bars pushed ahead all the way, maybe 1/4 from touching inner fairing where they are closest to the inner fairing. This in an attempt to make them sorta higher as I'm 6'2".
Not overly crazy about the thought that the 575's are closer to me?
Is this a situation where I should skip the 575's in favor of 578's?
Sorry for the thread hijack, your help is appreciated!
We always recommend taking a tape measure and have someone help you do this: Sit on the bike in the position that you ride and place you hands out where you want the bars to be. Have your assistant measure down to the base of the existing bar with the tape and you will have a good idea of what height you want.
Things to consider are: Hands that are higher than your heart may get numb on long rides due to blood flow. The higher the bar, the poorer the handling. The lower the bar, the more strain on your back.
Width, wider bars are usually more comfortable. Some riders prefer the Narrow look though.
If you are looking for a Wild 1 kit, Conventional Ape kit, Yaffe Bagger bar kit or PrimeApe kit, we have all of these available this month on sale. We have the kits with cables, brake lines and wire extensions to help make the process easier for the owner. Let me know if we can help you!
Thank you!
Ron
It's always best to take a measurement of what height bar that you really want. Body height to handlebar height is not a good consideration.
Thank you!
Ron
Thank you!
Ron
Very interested in going with WO 578's. Can I assume (I know I should never assume) that with the chubby's being 1 1/4" outside diameter, the inside diameter is also bigger? Or is the id the same?
If they are indeed bigger id, and the smooth bends, wouldn't this make these bars easier to wire internally?
Thank you!
Ron
