Change 2012 FLHRC beach bars
Thanks everyone!
Sounds like the only real gotcha is the left grip if it is glued on. Sounds manageable. If I can do this myself I save $150 which is what Harley wants to install them - that is $150 that can go toward my headers and pipes
Do I need to glue the grip again if I take it off? Is there something to use rather than grip glue?
Thanks!
Thanks!
Hey Everyone,
After a long"ish" ride of 400 miles this weekend I am convinced I do not like the stock bars on my 2012 FLHRC. I want to swap them out for the Heritage bars that appear to be stock on 2013 and newer. I have always suspected I did not like the stock bars.
My question is - how hard is this to do considering the throttle by wire stuff? I am a bit mechanically inclined, but not a gear head by any stretch. The bars seem pretty reasonably priced.
Anything tricky to be aware of?
Any other ideas for bars that are similar to the Heritage that would not require new cables etc...?
Thanks everyone and have a great day!
I installed Heritage style bars on my 2011 after my first tour also. They were about $80 but the dealer wanted about $300 for the install, so I did it myself. I found this VERY helpful thread with step by step instructions WITH PICTURES, that made it a snap. https://www.hdforums.com/forum/touri...road-king.html Couple that with the service manual instructions and it's an easy job. Read all the way through the thread first because others made suggestions that make certain steps even easier.
Thanks everyone and that is/was a great thread on how to swap the handlebars. I did not see that post until I had started and finished. I took it slow and used the service manual and got the job done. It was actually very rewarding since I am not that mechanical, but I feel good that I saved $150 (dealer cost to install).
One thing I did notice is that the left grip on my bike was not glued at all. Never twisted at all so that is how I put on the new grips. The switch housings go over the grip and when torqued they are tight and not moving.
All-in-all it was a learning experience and one that I am now happy I did myself.
The ride is a lot better in my opinion over the stock bars - more comfortable.
Thanks again everyone - your responses were very helpful.
Thanks for the quick reply! So do any of the wires run inside of the handlebars on a 2012? I believe they do and are you saying you have that on your 09 as well and it was pretty simple? I have the online service manual, but the section on remove and install of the bars is a bit lacking in my opinion.
Ron "Gunner" Retzlaff
09-20-2010 09:24 AM
