Heat demon install!!!!!!
Are you installing these on the stock bars? The TBW harness comes out of the handlebars in the middle below the radio. Follow the wires up to the plug and disconnect it. Then you should have enough slack to pull the TBW sensor out till the green plug is accessible. I installed these on my 11 EGC with WO577 handlebars. I had to ream the handlebar end out so the heat demons would fit over the TBW sensor and into the bars. I believe I read that they will fit into the stock bars without modification. Good Luck.
Edit: If memory serves me correct the plug is up on the throttle side fairing brace.
If I remember right the throttle side crosses through the bars to the left side. The left side runs out to power. See if this helps. http://www.harley-davidson.com/app-c...ts/-J05296.PDF
Ahooosier
2014-2023 Touring Models
15
07-31-2015 04:58 AM
