103" Touring Cams-TTS-100
These look really nice, they are strong on the bottom and carry out very nicely from the one sheet posted. I'd like to see a few more sheets from stock 103s without head/compression work to see if these numbers are the rule and not the exception. (Not trying to say anything about the fine gentlemen that have posted, just like to see more than one experiment before I believe the evidence as fact)
I'm more interested in seeing a sheet on a 103 wet - but FWIW I don't like the torque curve on the Wyrd cam. It's a nice number but too far up the scale. I'm interested in what is going on between 2.5 & 3.5.
From what I have seen the tts-100's hit 100tq usually 500 rpm earlier than most other cams. If that is important to you then I would take a look at them. My personal bike makes about 115 sq from a 103" and my buddy's '14 FLHX(a/c, JP headpipe, 3.5" RH muffs, thats all) with these cams is a hoot to ride. Does it run out to the limiter like my bike does? No it doesn't. These cams are another choice for those that want the TQ to hit early. Take a look is all I'm sayin.
Not looking for bragging hp or I wouldn't necessarily pick these cams. Maybe a little torque bragging though. I ride one up mostly and like quickness rather than top end.
Doc is going to do the tuning so I am hoping for a smooth holeshot cam only bike.
You will like these cams. And for the most part you will put the early hurt on dealer built stage 3/4 builds. They will call you a liar when you tell them you only did cams and a tune.
