Oil Choice For Primary (not a debate
Old 03-20-2015, 06:40 PM
Crazylegs's Avatar
Crazylegs
Crazylegs is offline
Default Oil Choice For Primary (not a debate)
I normally use formula plus for my primary but I have some mobil 1 synthetic 20/50 on hand and I picked up some screaming eagle synthetic blend for $2 a bottle a while back that I was just going to use in my lawnmower. Would either of these be ok or should I just stick to formula plus? Thanks.
Old 03-20-2015, 06:48 PM
wscott's Avatar
wscott
wscott is offline
You can use the SE syn blend in the primary without any ill effects.
Scott
Old 03-20-2015, 06:51 PM
lp's Avatar
lp
lp is offline
Received 2,720 Likes on 1,546 Posts
I've used 15w-50 Mobile 1 synthetic in the primary and found it "grabby".
I know it's not the same as you're asking but just putting it out there.
I only use formula+ in the primary now. Just works so well I have not bothered trying anything else...
Old 03-20-2015, 06:53 PM
smitty901's Avatar
smitty901
smitty901 is online now
Received 9,584 Likes on 5,162 Posts
HD F+ used it for years never an issue.
Old 03-20-2015, 07:08 PM
YPD485's Avatar
YPD485
YPD485 is offline
The Mobil 1 V-Twin 20W-50 can be used in all 3 holes.
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
put this stuff in and road to Daytona, Worked good so far and highly recommended by a transmission/primary professional
Attached Thumbnails Oil Choice For Primary (not a debate-gol_08_hea_dut_pri_cha_oil_1qt.jpg
Old 03-20-2015, 07:12 PM
Estil's Avatar
Estil
Estil is offline
I still just use Syn 3 in all 3 holes. Keeps things simple....... for me anyway.
Old 03-20-2015, 07:14 PM
Hard Ride's Avatar
Hard Ride
Hard Ride is offline
[QUOTE=voodoodrug;13829643]put this stuff in and road to Daytona, Worked good so far and highly recommended by a transmission/primary professional[/QUOTE
^^^ good stuff ^^^ Spectro
Old 03-20-2015, 07:17 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
Oil threads always turn into a debate.
Old 03-20-2015, 07:25 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,524 Likes on 1,421 Posts
You have spoken wisely.
Quick Reply: Oil Choice For Primary (not a debate
