ABS Light Staying On After Bleeding Rear Brakes
Old 03-21-2015, 03:25 PM
ggerline's Avatar
ggerline
ggerline is offline
Default ABS Light Staying On After Bleeding Rear Brakes
Last Fall my rear brakes seemed a little soft. So over the winter I installed new rear pads and bled the rear brakes. Today on the first ride, the ABS light blinked for the first few minutes, then stayed on solid. Rear brakes are working, but not the ABS function. Any ideas or help would be great.
Old 03-21-2015, 06:52 PM
FinalShot's Avatar
FinalShot
FinalShot is offline
Download the codes or use the on-bike function to read the codes and post them.
Harley Diagnostic Codes
To access codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI]
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
1 - Record the codes.
2 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 3 If the code is current it will reappear.
4 – Press and release the odometer reset button to continue to the next module.
5 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
Old 03-22-2015, 05:09 PM
SgtMic's Avatar
SgtMic
SgtMic is offline
I had to take mine in to the stealer so they could hook it up to the digital tachnician II.
semiret
07-20-2021 12:39 PM
jojeda
08-21-2012 11:18 PM
69cj
02-22-2011 04:34 PM
BC Glide
12-21-2010 06:59 AM
darrelld
10-07-2005 12:26 AM
Quick Reply: ABS Light Staying On After Bleeding Rear Brakes
