Engine Codes are Back......
In 2012, I had major issues with my Throttle. I was posting codes of
P0120 TPS1 Range Error
P0123 TPS2 high/open
P1510 EFI limited performance mode
P1511 EFI power management mode
P2135 TPS correlation error
and more...
I posted at https://www.hdforums.com/forum/touri...ease-help.html
I finally got it into the Stealer... they replaced the Computer and charged me about 900.... no change... finally they admitted it was a short in the TPS in the handle bar. But... I never got my money back for the new computer....
Anyway... regardless of what went down then.....
Here I am ..... exact same issues.... are back... FFS
I have checked all the connectors.... I don't see any corrosion, loose connections, or anything.
Any ideas?
I don't have the money for the Stealer...
Thanks!
and more...
Any ideas?
Thanks!
same issue on mine..had to replace the throttle body 1st time it happened, then i had wires rubbed through in the harness right where it splits off from the main harness to the throttle body harness...electrical issues are the biggest PITA things to find ..be patient, if your unsure about the work with your dealer find a reputable indy around your area..
FireHogRider
Electrical/Lighting/Alarm
18
05-04-2017 11:37 AM
Neildo
04-02-2016 01:48 AM
