Question On Internal Wiring With a Bar Swap
Im sure this has been covered many times, but my frustration right now doesn't allow my patience to search correctly. I am swapping to 12" Yaffe style bars. I have the sharp corners on top and also on the bottom, the lower ones are a bit extreme. Anyway, I have wrapped all my wires with an expanded sleeve to try and keep my wires protected form the sharp corners. I am having a hech of a hard time getting around even the first bend. All of the videos on YouTube show the wires to be exposed and not in any type of loom or heat shrink. This would seem much easier to pull through as the end of the wires can be staggered to prevent the initial bulge going through the corners. But my question is, will those corners nick the wires while pulling? Or will the corner rub through the wire over time? HELP! Thanks
Ill give it another shot guys. Maybe the chain is the trick because I have tried string and #14 solid copper wire to pull it and it seems that both of these got hooked up on the corners. One more question...... I still have my pins on my wires, I staggered my splices in between the pins and the switches. Do you see this being any issue?
I am in the process of doing my bars. Carlini 14" Gaster Apes. Like all other are saying, shrink tube the wires and not black tape (will explain next) and lube up. Push the wires through the hole, then pull the other end. Like a dance (or something else), push, pull, push, pull...
Depending on the lube you use, some will eat at the black tape and it will come undone.
For lube, dont use tons either. A little goes a long way. Vaseline, WD40, dish soap are all types you can use. There is stuff out there you can buy that does this job as well. Sometimes nicknamed camelcome.
Patience is # 1 as well.
Good luck!
Good luck!
I have it wrapped in this expanded sleeve now, my thought was this would be more flexible over shrink tube and it has a nice slippery kinda feel to it. But maybe its not a good option as I cant really "push" this through as its not rigid enough. I will try to shrink tube it and see if I can get that to work...
I had some of that I was going to use when I wired my KST mayhem bars up, but didn't think it would work so well.
