Wheel Bearings
These things are industry standard bearings, so unless you have ABS you should be able to get replacements from any decent bearing shop. The brand RAP identifies look good, however if your bike is a 2004 you need 1" ID bearings, not 25mm. If you shop around take one of your bearings with you, as the numbers engraved on them will tell a supplier everything they need to know.
Received 47,780 Likes
Surprisingly, I have found that the bearing is very common. The only one that is hard to obtain is the ABS bearing. I had a lot of failures with the Harley bearings on my 2009 RG, those bearings were a real piece of crap. At that time, the bearings had to be replaced at the same time as the tires (12K-15K miles). Twice the bearings were covered under warranty. After that I did not care if they were free, it was not worth the risk of serious failure out on the road and I just sourced them myself.
I'm not sure about the bearings but 1" is equal to 25.4mm so either size should work. Most bearings are made by multiple manufacturers and usually can be crossed referenced. With no local suppliers nearby you could try MSC Direct or McMaster Carr and have them the next day but will pay a little more.
