Street Cannon, Cobra Power flow header...
All,
Here it is...I have a 14 ultra. Have Street Cannons with about 5k on them from the stock header. Got tired of a medium-rare right lower leg and foot. Installed Cobra Powerport header and tuned with sepst and my tune ( have big sucker installed as well). The sound of the SC's at idle is Ok and they most assuredly bark while getting on it but....and maybe I'm getting old...the sound is just a little bit too close to obnoxious for me.
As an experiment I've taken off the SC's and put on the stock cans...they're a little too far away from obnoxious..... Louder than original stock but not much.
I've taken apart the SC's...really easy to do...take off end caps, remove from bike, remove torx safety screws, 2 per can, hold the can vertical with big end down and tap with a piece of wood around circumference of big end and baffle begins to slip out...nudge a little, pull out perf core, then gently work baffle material out around the ScreaminEagle name plate rivets...
I'm really looking for what I can do with the SC's to mellow them out a bit as I want sound between the stock cans and the SC's with the Powerflow header......I'll try to post some pics of the taken apart SC's.. Any ideas??
That packing looks like a loose fit. I've run this techmat on 2 different baffles and it works well. Wrap it tight with as much as you can.
http://www.ebay.com/itm/like/1416130...lpid=82&chn=ps
I've got screaming eagle mufflers I bought off a member here. The sound was too quiet, so I ordered baffle parts from fullsac. For me, the 2" core worked out good, little louder at idle an takeoff, but not too bad at speed. I still haven't been able to go for a long ride because of the cold and rain, so can't comment on whether or not it's gonna bother me. If you can weld or have someone do it for you, that is an option. They do have a cvo baffles that might work, if you still have your baffles out, you could call them to get dimensions for comparison to yours. Now my SE mufflers had sheet fiberglass material that was held against the body of the muffler with metal screen, fullsac recommends this and sells a screen material that can do just that. I believe that it cancels out the higher frequency tinny sound you can get from some slip ons.
The real question here is not how loud they are with the Cobra headers but the quality of the sound? Most that have tried the SC's with and without the cat has thought that once the cat is gone the sounds is tinny, metallic or just plain poor tone. I like the deep rumble with the cats, if I could get that same tone only a little louder I'd be happy to keep them.
Mhsmith451, After putting Fullsac headers on my 14 Limited along with the Street Cannons, I decided to put Big City Thunder Baffles in the head pipe. https://www.bigcitythunder.com/order...r-baffles.html
Still have that low rumble but not obnoxiously loud. You might want to check them out.
Kj
Kj
