High oil and head temperatures.
100 degrees ambient is not warm, it is hot, hot, hot. Those oil temps are also pretty hot, but I don't think they are critical. The first thing that came to mind is "I wonder how fast they were riding?" If you were in downtown traffic going from stoplight to stoplight, that would be normal. If, on the other hand you were cruising along on the open road at 60 mph, then I would think those oil temps were unusually high.
How will that lower engine / oil temperature?
Riding in 100 degree temps is quite normal in CA. Those temps do seem high. I don't believe that my 2011 Ultra has ever run that hot and I've ridden in temps up to 108.
Harley test these bikes in the AZ desert. Hell i have seen a video where they start the bike and park it a closed off area and let it idle for hours.
The bike can stand more heat than most humans can.
Ride it. If you get hot pull over. Heat stroke will do more damage to you than heat will do to the bike
