what options do I have for turn signals
nicer...the lollipops are part of the classic Harley look, similar to 2 spots and a headlight up front or the batwing fairing...instantly signifies Harley-Davidson Big Twin FLH
Makes a visual cue that you are not rolling up on an import wanna-look-like.
but we each have our own eye and what appeals to it.
there are kits to sink lights into the saddlebags or a filler strip between bags and fender...or just a streetglide signal bar.
options may vary with your model year ( I don;t know what FLHTCU you have)
suggest you spend some time looking in catalogs and pics to see what best appeals to your eye and will look best with other changes you have in mind
factor in whether your tour pak is on or off.
I swapped over to a roadking signal bar...a little narrower, plate mounts under. solid red lens, mounts with same to bolts- requires a splice to marry the plate led into the fender tip light.
since this pic I added the run/turn/brake module so my lenses are now red
easy, this is a 2009 model with a 2010 RK bar...cost about $70 used
Mike
Mike
there are kits to sink lights into the saddlebags or a filler strip betwen bags and fender...or just a streetglide signal bar.
Mike
Mike
4shongo
04-08-2014 11:08 AM
