My bike won't start. A few weeks ago I put in a new stereo and drained the battery. I but the tender on for a day and it fired right up.
Today I go to start and nothing.
The lights are on and bright but when I turn the kill switch to run I don't hear the ecu firing up and of course nothing on the start button. Not the slightest.
Key fob battery? Two years ago my bike stranded me. I went over everything that I could think of. I called a friend and he told me to try a battery in the fob. That fixed it! I change it every spring now. I hope your issue is that simple.
Hard to say why the fuse blew.....I would probably carry a spare.....just in case it happens again....and needless to say it would probably be a place not as convenient as your garage
My problem still exists
I bought a new relay today and When I turn the main switch to ignition I hear it pop. I don't even get to the run to start switch.
Maybe a pinched wire inside one of the handlebar switch housings from when you changed the grips? Also, if you're not really careful, you can break the front brake switch when putting the grip housing back together. Possible cause of a short.
