Android App: TwinCam Reference
#33
Another quick update... there has been an update to the content ... and also an update to the app to address a bug and also to add some features ... specifically the app will periodically run checks for new content and turn the setting icon on the taskbar green if it finds an update.
There is a new setting on the settings panel to enable how often you want the app to check. It will only do so when the app is open. Its not perfect, but is a little better then just periodically running update from settings to check.
hbsoldier3 (09-12-2016)
#35
#36
For those of you concerned about app permissions; You may want to look into an android application called App Ops.
This app requires root authority and at least version 4.4.2 (KitKat) of the android operation system. It is on the Play Store and I have no connection with it but many report on it very positively on the XDA Forum and other android discussion groups. I use something similar on the Cyanogen version [CM12.1] of android (app called Privacy Guard) and it is very comforting to have complete control over all apps INCLUDING Google's apps.
Cheers.
Cheers.
#38
