Inner primary and primary gaskets
Old 04-14-2015, 04:15 AM
Big Money's Avatar
Big Money
Big Money is offline
Default Inner primary and primary gaskets
Had inner primary off about 500 miles ago, put new inner primary and primary gaskets in when I reassembled. I'm removing them again to install Baker comp. Can I reuse the gaskets since they were only on 500 miles or should I replace them. I have new ones, just hate to waste gaskets if they are good.
Old 04-14-2015, 05:05 AM
shadowchrome's Avatar
shadowchrome
shadowchrome is offline
You should be fine.
Old 04-14-2015, 05:51 AM
bagga's Avatar
bagga
bagga is offline
drain the oil into a clean pan and reuse it along with the gasket.
Old 04-14-2015, 08:43 AM
J929626's Avatar
J929626
J929626 is offline
Gaskets are relatively cheap. I would change them.
Old 04-14-2015, 08:51 AM
lp's Avatar
lp
lp is offline
Received 2,720 Likes on 1,546 Posts
Ive used the same gasket like 8 times.
Save the new one for when you actually need it.
Old 04-14-2015, 10:16 AM
MCSarge's Avatar
MCSarge
MCSarge is offline
Due to the amount of work required to change them if God forbid one goes bad. I would change the inner ones for sure. The outer gaskets are easier and quicker to get to if there is a problem.
Old 04-14-2015, 05:03 PM
Big Money's Avatar
Big Money
Appreciate the input, for the $40 I'll replace them.
Old 04-14-2015, 05:25 PM
fat daddy's Avatar
fat daddy
fat daddy is offline
I wouldn't necessarily call $40.00 for a outer primary gasket relatively cheap. I've used mine many times over. Just be careful how you handle them.
Old 04-14-2015, 05:27 PM
williamfrog's Avatar
williamfrog
williamfrog is offline
What he said
Old 04-16-2015, 03:35 PM
brutalbrad's Avatar
brutalbrad
brutalbrad is offline
If the primary chain case cover gasket is damaged or deteriorated in any way, replace the gasket prior to installation of the primary chain case cover.
above is from instructions to install Baker Comp. I tend to always have the gaskets available. and swap them. but i looks like you can reuse away if no noticeable damage.
You also stated only 500 miles ago... i would tend to believe the are fine. Nothing work then doing work and not having the proper O-Ring or gasket on hand depending on the distance you need to travel to get one.
Quick Reply: Inner primary and primary gaskets
