Fullsac CVO power core mufflers louder than stock?
I have a set of mufflers off a 2013 CVO Ultra Classic on my 14 Limited. I'm wanting to make them flow like a stage 1 muffler but don't want louder than stock. Are the Fullsac CVO power core's in the 1.75" and 2" sizes louder than the stock CVO mufflers? What effect do the muffler sleeves they recommend with power cores have on the sound and volume?
I pull a trailer behind my Limited on all day rides. The weight of the trailer makes the bike pull harder which increases the sound level plus the sound reflects off the front of the trailer. I don't want to make it any louder than it is now when pulling the trailer.
The majority of aftermarket mufflers throw the EPA noise regulations out into the garbage! Look for performance mufflers that say they are quiet. There are not many of them, so your search should be short. S&S offer quiet SPO mufflers. If a brand makes no reference to being quiet, you can be confident they ain't!
Slightly louder would be OK. Did you use the muffler sleeves and remove half the packing like Fullsac recommends or did you just leave some of the packing material out?
The tape makes it much easier to get it stuffed in.
The Fullsac CVO Baffle Screens are well worth the price!
You wrap the insulation on the outside of the screens. The screens then keep the wrap in place on the inside of the pipes. This will keep the insulation from sinking to the outlet of the baffles. (Which can sometimes come out of the mufflers tips) also, making it very easy to change out your baffles to different sizes if you desire!
As you can see the Baffles Screens are on the left of the stock crap stuff!
And yes, the 1.75" are just slightly louder then stock.
YB
YB
I used the 2" cores in my screaming eagle mufflers (which I had to alter) and they are louder but not too bad. The screen is the way to go keeping the packing away from the core, I think that It helps cancel out some of tinny sound you can get from some mufflers/baffles. They are great folks to deal with at Fullsac, highly recommend them and their product.
