I turn the ignition and all my panel lights came on...so far it's all good. Then I hit the starter and all I hear is "click, click, click..."
Originally Posted by Nute
Make sure your "kill" switch is in the "run" position and transmission is in neutral.
If the "kill" switch wasn't in the "run" position, he wouldn't even get the "click, click, click" sounds he describes.
That clicking sound is a symptom of a bad connection somewhere, or a very low battery.
There is not enough voltage to turn the starter over, thus the clicking sound.
Any update? I agree it sounds like a power issue. I would put a full charge on the battery and then try again. If it still does it then start at the starter and go back to the battery to see if something is not correct. I have seen quite a few times a ground loose or the hot on starter. Put a wrench on them to see. Recheck the battery connections also.
The green wire, where it hooks to the starter, has been known to corrodeand go bad.. Drag Specialties makes a remote starterbutton that bolts right on the end of the starter (yes, it's chrome) that I will be putting on mine when I get tires in a month or so..
