Help Air Shock Issues
I am having trouble with my stock air shocks. They are stock and when I try to pump them up the needle on the pump raises very high. I have tried to add and remove air but cant do either. I have tried another pump and it does the same thing. Any ideas.
It is a 2007 Ultra Classic.
Received 2,524 Likes
Also, one other thought, make sure that the pump you are using is able to push down on the spring loaded valve stem. I just remembered that before I bought the harley pump, I had picked up a bicycle pump at walmart. That didn't work and thinking it was the pump, I returned it and picked up another kind from Academy. Same problem and it was because it needed to slip further down the stem in order to release the vale.
I had this problem on my air shocks also, the shock oil degrades the rubber o-ring in the air valve,go to the auto parts store and get a valve stem remover and new valves stems and replace them,costs about$5-6,cheap easy fix.on my new RK I replace the air shocks with OHLINS and got rid of the air completely,was expensive but so worth it.
